Is it possible to have more than 3 OR clauses in a flow? I have this flow I need to activate on set dates, and the easiest option for me is to do it once per year. That means I’ll need up to 12 OR clauses, or at least 6. Is this possible in some way? Or is it possible to add an array of dates somehow?
Or if you really want to do it in flows, think the other way around:
[IF] trigger
[AND] date isn’t ****
[AND] etc…
[THEN] do what you normally would do, not on those dates (I believe it is optional to have cards in the THEN)
[ELSE] do what you want to do on those dates
Do you have experience with using logic operators to compare the title? I think I got the ical app working, but is there a way to do a case insensitive contains operation on the title? Or is the problem that “contains” from the logic group doesn’t trigger if there are 0 characters before the string it should contain?
