I have been playing around with moods for a while, but it is not working the way I expected. In my living room I have 8 lights, some of which are rgbw and some are just white light. When setting up a mood with all 8 lights included, everything looks ok. But then when I activate the mood I can see all lights being turned on at first, but then some of the white lights (Fibaro Dimmer 2) are turned off. Happens to all my moods. Anyone else experiencing this behaviour? Makes flows pretty much useless for me.
Thanks for the tip. However it didn’t give me any info to use. It is just saying that Fibaro is the client and the capability is onoff.
Ah, bummer.
A thing to keep in mind:
When a light is on, and then it’s dimmed to zero by what or whom, the device log says "turned off by [app name], Fibaro in your case.
Thanks! That detail helped me!
Seems like all the moods are stored with dim level zero on the Fibaros, even if that was not the case when creating the mood. Probably a bug there. After changing the moods, the Fibaros are now consistently on.
Thanks for your help!
