Midea Heat Pump with KJRH-120F
Dear Homey users,
Let me ask your help. I have a midea heat pump with KJRH-120F wifi capable control panel.
I am a little bit lost which kind of device it would be in homey. Do we have any supported way to add Midea Clould or direct integration with this device?
I have just the officially app which called MSmartHome (MSmartHome). But not sure this would be the way. I haven’t found any midea called app. But maybe there is another branded app which can handle this.
In case somebody has info about it please share with me.
Thanks!
Best regards,
Mihaly
Did you figure it out already? I have the same question, but it seems right now there is no app for this.
No response on homey side, neither on midea side. :frowning: so i need to use the midea app to control the heat pump.
At least we are two with the same tech base :slight_smile:
Have the same question
/j
The Midea eco system is on my radar for adding support (as a community app) but I will say that I am doubtful I would be adding support for heat pumps as I don’t have one myself.
Great to hear it!
Not sure how the API system works and how special the heat pumper. However, let me know if you need just a test system. I can be a tester with my system.
I would be happy if the Midea stick was supported.
Unfortunately there is no adapter in Iobroker.
This stick is built into many Midea devices.
For me it is a dehumidifier.
The devices are now controlled with the smart home app.
Hello
itfff is linked to the smarthome app (Search for 'Midea' - IFTTT), but I don’t want to share usage or any data with an external provider, which is why I chose Homey instead of Google home for example. I trust it is really on your radar yet and will be supported by Midea sooner or later. I spoke to Midea customer support to get support for Homey as a smart home hub, but I didn’t get a substantive answer… the new mobile app (SmartHome) is much slower than the previous one (Midea Air), plus it doesn’t install on a computer, so I can’t control it from there anymore either. But most annoying, it is terribly slow, I start the app and nothing happens for 10 seconds… :frowning:
so stuartp44 please save us :slight_smile:
The midea-app is so bad.
It doesn’t even send a push when the tank is full.
I’ve now installed a z-wave flood detector on the tank.
sad…
I know, but if I could control nothing but the on/off switch of the air conditioner I would be happy. :slight_smile:
I’m in the same boat. did anyone find a solution for this ?
I searched the request brand section but nothing showed up.
regards,
z
