MicroMatic ZB250
Has anyone tried this with Homey and does it have energy metering?
Hei
i have this installed and its working perfect also energy metering i had i for few months now
Thank you for the info :slight_smile:
How does it look when you have added it to Homey?
Is it the normal on/off button, dimming, energy (W) and energy (kWh)?
Like this, I only used standard setup as you see :+1:
Thank you very much :slight_smile:
They are on sale now for 599,- so I think these would be perfect.
I have a few from Namron before (Z-wave). Look at the connection here, there is no N phase.
Is it the same for Micro dim ZB250?
Nice on ZB250 you have both options use with N or without N its a rely good Dimmer that can be used with any power net you may have :smile:
I am very satisfied with the dimmer, but lately, something weird has started to happen.
The app (MicroDim) is turning the dimmer on itself. This is not good and I need to stop it.
Anyone else experiences that devices/switches/dimmers turn themselves on and how to prevent this from happening?
In this case, is there any adjustment/properties in the app/device?
My flow is the two at the bottom, but the one at the top should not happen, (says “turned on”) :open_mouth:
Ten hours ago, the same happened.
The app turned the dimmer on, and then off.
Every time I restart Homey, I have to take the power off and on the MicroDim for it to reconnect to homey :open_mouth:
I cant get this to work.
It misidentifies the product as
As sz1000.and places it as generic Zigbee
Instead om namron zb250
Any fix? Tried it on all 30 and the same with everyone, even reset wont help
