Hi all, I have been trying to connect to Mi Gateway (v3) via Homey and had no luck. I’ve used correct token and ip address (I am sure because I’ve got success with this ip address and token via Domoticz and Raspberry Pi). Could somebody clarify what I am doing wrong?
I have the same Problem. Did you found a solution for the problem?
I have the same problem, any suggestions?
