Matter multi-admin failing - Homey Pro Mini + Apple Home + Eve Thread devices (Matter)
I have a Homey Pro Mini and a solid Apple Home Thread network (2× Apple TVs as Thread Border Routers, multiple Eve Energy plugs and Eve Motion Blinds). All devices work perfectly in Apple Home and form a stable Thread mesh.
I’m trying to add these Eve devices to Homey via Matter, either by:
  • Adding them to Apple Home first and then attempting multi-admin, or
  • Factory resetting and adding them again
In all cases, Homey goes through the Matter commissioning flow but fails at the final step (“unable to connect” / commissioning fails at the end). This happens consistently across multiple Eve Thread devices (plugs and blinds).
Key points:
  • Homey Pro Mini does have a Thread radio
  • Thread mesh quality is good (devices are responsive in Apple Home)
  • Devices are definitely Matter-enabled
  • Distance / signal doesn’t appear to be the issue
  • There is no generic HomeKit controller/bridge in Homey, so Matter is the only integration path for Eve
Has anyone:
  • Successfully added Apple-owned Eve Thread devices to Homey via Matter multi-admin?
  • Found a reliable commissioning order or workaround?
  • Identified Apple Home / Eve firmware limitations that block Homey specifically?
At this point I’m trying to understand whether this is:
  • An Apple Home multi-admin limitation
  • An Eve firmware issue
  • A Homey Matter/Thread implementation gap
  • Or simply not supported in practice yeT
Any real-world success stories or confirmed “this doesn’t work” answers would be very helpful
Hi Matthew,
I’ve 2 AppleTV as Thread border routers too and 14 Eve Energy to extend and build a stable thread network. After that I set every Eve Energy in pairing mode using the apple home app. Now I can add it to Homey using the iOS connection mode:
New Device → Matter → iOS mode → enter pairing pin → wait some time and it should connect to homey and added as new device
You should take care to use the latest Homey OS 12.10.1. On version lower than 12.8 I’d issues with connecting Matter-over-thread devices, but Homey is working on Matter too. At the developer page you can see all connected Matter devices.
Greetings,
David
I have the latest Homey version and just tried to reconnect my Eve home plugs using the process you described, which is just what I was trying to do before, I got the same error message and couldn’t connect. It goes all the way through the pairing process but fails at the end saying ‘try again later’. Any suggestions or pointers would be very much appreciated.
I’m sorry - I’ve not idea how you can fix this. I’d problems with Eve components too. But after creating a stable thread network, it’s fine for now. Maybe this helps you:
  • AppleTV → you can switch the master thread border controller from AppleTV 1 to 2. This can help, if the AppleTVs are to far away from each other. I would recommend to put some Eve energy between both to extend the mesh network.
  • Base Network → if you are using Unify with IPv6, you have to configure mandatory settings to work in a Unify network environment (don’t remember which ones, but you can find it with Google - e.g. MDNS)
