M-bus connection
Are there any possibilities to connect to my wireless M-bus units that registrates water-, heat- and electrical-consumption? My units are installed by Mälarenergi in Västerås Sweden. In fact I don’t know if they are on 868MHz or 433MHz. Both frequencies are available for M-bus standard.
The only way I can discover so far, is this (probably not easy peasy) solution below. (When M-Bus messages are converted to MQTT messages, you can use them with Homey):
Did you get any further with this?
I’m intetested in doing the same. Reading both water consumption and my heating wich is “fjärrvärme”.
Hi Tobias
Unfortunately not. No-one seems to have done this, and I am not skilled enough to start programming this myself. So I gave up.
BR Johan
Hej,
Jag förstår.
Har inte heller kunskap om programmering.
Vi får se vad det landar i.
Tack för svar i alla fall.
Mvh Tobias
Den tis 8 juli 2025 14:38Johan Svartengren via Homey Community Forum <notifications@athom.discoursemail.com> skrev:
