swap83
August 14, 2022, 8:15am
1
Sorry for my English
My homey lost wifi for 2 times.
I must put it in the recovery mode and reconfigure the wifi as the first time.
My configuration (app, flows, etc) there are yet!
original power supply
SSID wifi only 2.4
others device nothing problem with same wifi.
swap83
August 14, 2022, 8:26am
3
Really?
Why the power supply causes the loose wifi?
robertklep:
swap83:
Try a better one.
The original power supply is known to be of bad quality, and can cause all kinds of random issues.
Maybe there’s a useful hint here:
Make sure your WiFi is using the 2.4 GHz network.
Make sure your WiFi uses the b / g standard, only n or ac does not work.
Turn off your Homey.
Restart your Router and any Access Points that distribute IP addresses.
Start your Homey again.
If the above do not work, turn off 5 GHz WiFi and support for n and ac in your Router / Access Point during Homey installation.
Ensure that your SSID (the name of your WiFi) does not use characters other than numbers and letters - do not us…
swap83
August 14, 2022, 2:16pm
7
I did it all @Peter_Kawa
My homey after **some time ** the wifi connect
