Let me start by saying that I am still very happy with Homey. Generally everything works fine only recently I found out a problem that I don’t know the solution to.
I have connected to Homey a lot of Zigbee devices and sensors. Due to the good number of routers and repeaters, I think I have built a good mesh network. Now I have the problem that a number of sensors, mainly Aqara, regularly lose connection when the route runs through a Robbshop dimmer (of which I have 4 in the house). All other routes work fine but every time a sensor connects through one of these dimmers (router) the connection is broken quite quickly. By the way, the dimmers function fine as dimmers in combination with Homey.
I have already tried to bypass the routers by restarting homey when the power is off the dimmers causing the senors to get a different route. This works for a while but when the power goes back on the dimmers they are slowly included in the network again and sensors are automatically linked to them again.
I am very curious if anyone else recognizes this problem and knows a solution? And whether it is possible to indicate in Homey that a router may not function as a router but only as an end device?
Thanks in advance for thinking along!
