How do i accomplish fading my lights on and off in a flow?
If your light support dimming, you can set additional the duration of an action.
Otherwise you can try the app Dimmy, but this has limitation in duration, a bit to quick in my personal opinion.
Next step is building your own transitions, with the app Chronograph.
edit: welcome on the forum
Thank you @sschot. I’ll give Dimmy a try. It worked occasionally in Home Assistant and now I’m trying Homey Pro.
The Transitions app is also useful for this.
I’ll give it a try. Thank you
Hi, I’ve written an app that might be able to help you with that. Once you’ve set up a mood for your lights, you can fade into that mood.
