Hi all hope can be usefull for everybody have issue with KNX / CABLE / ETH with homey.
I try many things like this:
- Original (2version) PSU from ATOM with Original USB C-C cable, WIFI 5ghz or 2.4ghz
- KNX work, lost wifi or connection to HOMEY often - Original (2version) PSU from ATOM, Original USB C-C cable, Original ETH-USB cable
- KNX not work, other things work with instable CPU Clock - Chromecast 4k PSU with built in ETH and wifi
- work with instable CPU Clock** - Original (2version) PSU from ATOM, short not original USB C-C cable, Original ETH-USB cable, WIFI
- work with minor instable CPU Clock - 2M not original USB C-C cable (pro), Original ETH-USB cable
- KNX NOT work with minor instable CPU Clock
So in my case solution 3 and 4 are the most usable cause i have a lot of KNX integration (i suppose original USB cable are not good so the telegram sent from homey to knx going lost, and this is the reason why is work with WIFI)
Do you have a chance to test some of this different case and confirm? I will continue to test different usb C-C cable and see if something change.
Actually KNX not work only in ETH modality.
Can someone confirm my test??? Thanks in advance
