You need a gateway that will show up in https://mijn.ithodaalderop.nl/
Since that is where the app reads the data from (via the API over internet, not via USB or a (zwave,zigbee,bluetooth) wireless protocol)
Hi, I have a gateway since one week. It worked fine in Homey, but not since yesterday. I am able to control my gateway through the itho app and website, so it is properly connected. I also made sure the password is correct. Is the API down or so?
I am using the exact same api as the mijn.ithodaalderop.nl site is using, so unless they’ve changed the protocol it should be working in the app. I checked it and for me it is still working. Maybe you can try to remove and reinstall the app in homey, or else send a bug report so I can check the logs.
Found the issue: 2 days ago I changed the zone name where the fan is located, so now I had to re-add the fan to Homey
@LvanderRee, I’m looking into a solution to automate my Itho boxes. I’ve got two of them. Does your application allow adding both?
I still need to buy the gw box, but if it’s not going to work, then I definitely won’t buy it. It is offered a lot on marktplaats.nl for ~100 euro’s. But it is still a bit of a risk if I’m not able to control both.
@LvanderRee Hi Leon,
Very Nice job. I have 4 spider thermostats and one ventilation unit installed.
Is it possible to import itho daalderop powerplugs into Homey?
Hello @Reinemanz and @Martijn_Hoogenbosch (sorry for the delay)
I can handle everything that you can see in your https://mijn.ithodaalderop.nl/#/dashboard , since I simply call the same API via the Homey widgets I’ve created.
However since I don’t have daalderop powerplugs nor two itho boxes, I cannot test this myself, nor have I written code to support this.
Thanks for coming back to it. I’ve solved it in another way. I’ve used the periflex connection to connect a shelly 2.5, works good enough.
@LvanderRee First of all: Thank you very much for all the work you put in this project. I’m new to Homey, but the main reason of buying a Homey is to control my Spider system. I use a multi-zone Spider system at home. What I still couldn’t figure out are these things:
I will keep following this topic. Keep up the good work!
Hi Leon, I am using Homey since a couple of months. Connecting the Spider thermostat is still a problem. Connecting the Spider Ventilation unit is OK and works well. Can you help me connecting the thermostat?
Ofcourse I use a Itho/Spider gateway.
Thanks in advance,
Jos
you can read the clock program, when you navigate to the details overview:
I actually haven’t changed the temperature in flows via Homey myself all this time, so I haven’t missed the option to read and alter the clock-mode myself, but it should be possible to add this feature for flows as well.
Reading out the smart meter should be possible as well, just didn’t put effort in it yet, but maybe I can find some time in the coming days.
Adding support for power sockets is hard, since I haven’t got them myself, so I cannot debug the API calls that are exchanged via mijn.ithodaalderop.nl
Hi, is it already possible to retrieve the smart energy meter readings from the Itho gateway as well? Would be really nice!
I’ve updated the app, it currently is in test: https://homey.app/nl-nl/app/com.synplyworks.spider/Spider/test/
I think I fixed the issue where some of you could not add the thermostat (when you have rooms wthout thermostat, the itho api returned a state telling me there is a spider, but you cannot change the temperature…I didn’t expect that)
I’ve added some extra cards to control the thermostat mode (read demand, set schedule-mode and heat/cool)
I also added a new option for the fan, to completely turn it off
I just bought a new Itho setup and all is working fine in the https://mijn.ithodaalderop.nl/ but I’m not able to connect the device in Homey. I receive Time outs all the time. Any help here?
Ik denk dat ik je crash report heb ontvangen, met het volgende bericht
Unfortunately, your app com.synplyworks.spider (v0.5.0) has crashed.
Note: this log has been manually submitted by a user.
Log ID: 513c01b7-8353-450e-87cc-c1aeed9577bc
User Message:
Ventilator doet het wel in mijn Itho maar krijg hem niet gekoppelt
Met de volgende melding in de crash :
authentication failed: {“error”:“invalid_grant”,“error_description”:“E-mailadres of wachtwoord is niet correct.”}
Denk dat dat voor zich spreekt, en lijkt een goede verklaring.
Wellicht dat ik deze situatie nog niet goed afvang, en niet toon dat de inlog niet gelukt is, maar mocht het niet werken probeer dan nogmaals username en wachtwoord opnieuw in te voeren.
I’ve had some time to try and implement the P1 smart meter functionality.
I’ve updated the version you can find in test: https://homey.app/a/com.synplyworks.spider/test/
Hi Leon, I will install this New test version today and do Some tests. I’ll let you know if it’s OK.
Thanks a lot for your work.
unfortunately the powermeter that is retreived via the API is delayed by something like half an hour and there doesn’t seem to be a way (yet) to add a timestamp to the meter-data to tell from what date the data is from.
See below an example of the heat-pump that is warming my house, but my smart-meter shows power-usage half an hour later…
Version 0.6.1 has just been promoted from test to stable.
You should add new devices and selected your spider to add the smart-meter. Be aware that the usage info is delayed with something like half an hour, but at least you get the info in Homey (only shown at the wrong timestamp). Unfortunately I cannot fix this, until Homey add a function to provide time-information along with the power-meter value, or when Itho can reducing the latency via its API.
I’m trying to finish my account under mijn.ithodaalderop.nl with the 10 numbers serial code but where can I find this 10 digits serial number to finish my account. I have found the MAC number of my itho CVE RTF wifi add-on unit, but I also need the serial number. Can someone help me with this?
