Hello.
I want to control a fibaro smart plug where I have connected a MILL heater. I installed Virtual Device and added a thermostat.
I have an external temperature sensor from Aqara that I need to get temp. info from. I have made 3 flows to control this. But it doesn’t work quite right.
It can’t read the correct temperature from my temperature sensor. It shows only 22.5c. And does not change if the temperature in the room changes.
I only manage to “override” the temperature manually so that the oven turns on / off.
Is there anyone who can help me and see what I’m doing wrong?
I’ve tried the Virtual Device and Vthermo apps.
Here is 2/3 flows (can only post 2 links??)
https://homey.app/f/eS99DZ
https://homey.app/f/q1d9DZ
And here is temp.sensor and thermostat temp:
