Issues adding Gledopto 5 in 1 zigbee controller in Homey Pro
Hi there, I have a Gledopto 5-1 ledstrip controller And want to control a RGBCCT led strip via Homey. I found the Gledopto device in Homey but get various errors when trying to add. It sometimes adds the device but then on/off/dim, etc do not work. It should work but very unclear what I am doing wrong. I managed to connect a zigbee remote and that works but I really want to use my mobile/Homey to control and create flows…
Can anybody help me?
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum post here.
So:
  1. What Homey do you have, or is your Question about?
  2. For Homey Pro only - firmware (fw) version.
  3. Problems with an app: what App, What Version.
  4. Problems with a flow: Share your Flow!
  5. Problems with a device: What Device, What model/ Part Number, how many have you tried?
  6. What have you already tried yourself?
  7. And last but not least, Have you searched? For What?
I have the same issue with 5 in 1 led driver from Gledopto. Have you find out anything? Have you solved to connect the driver properly to Homey?
Hello, same here. Any solutions yet?
There is a test version of the Gledopto driver available. I have been using it for two weeks ans seems to have solved the issues.
Go to the Gledopto Official page (GLEDOPTO App for Homey | Homey). Scroll down to the “What’s New” section and click on the Change Log ->. This will open a pop-up window listing driver changes. At the top of the list is the version 1.1.6 with an orange test button.
Click the button to access the Install window (note the warning). As I said it seems to have solved the issues.
Or just add Gled devices as generic zigbee device. It solved all of issues for me.
Do I have to uninstall my Gledopto devices and then reinstall them again after I have downloaded the test app or will it work automatically? I downloaded the test version and some lights started to work while others didn’t. I have noticed that sometimes they work and sometimes they doesn’t quite randomly with the old version, so not sure if just downloading the test version was an improvement or just luck, therefore the question :slight_smile:
Hello. It works with Gledopto gl-c-601p zigbee. Thanks a lot
