Having an issue that I can’t seem to figure out with a simple flow- “when” it’s sunset - “then” turn outer light to “x” color. The issue I’m having is the light will turn on but it won’t set it to the color I select and will only turn it on to the light color I had previously even though it’s set to a desired color. Any ideas on why this is?
No, no idea, sorry.
I know it’s just a workaround and maybe not what you want, but can’t you turn the lights on and then immediately adjust the color? So two “Then…” Flow cards directly after each other.
However, you should better ask in the relevant app topic anyway. The app developer may be able to tell you if it’s a bug or due to software and/or hardware limitation.
Thank you for the response. I tried the two “thens” but still to no avail. I will post in that thread. I appreciate it!
