Is my flow for the curtains ok for closing with different variables?
When the sun goes up in 10min, season between october & april all the curtains open up. Bedroom curtain opens up only if nobody’s home.
When sun goes up in 10min, season between may & september, and inside temp is over 23 & outside temp is over 25 then everything stays closed BUT if false everything opens. Bedroom opens if nobody’s home.
Is this correct? Thanks
For the flow between may & september.
Do you want the curtains to open if both the inside temp is below 23 and outside temp is over 25? Or just one of theese?
For now the flow will cancel if the inside temperature is below 23, and dont check the outside temperature.
I want the curtains to remain closed if it’s over 23 inside and over 25 outside.
Open if it’s under 23 inside & over 25 outside.
Open if it’s under 23 & over 25 outside.
Thanks
You should also draw yellow lines between ‘inside temp is higher then 23’ and the ‘open curtain’-cards.
(I assume that the curtains are closed during the night, so there is no need for the ‘close curtain’-cards)
(If you add a ‘somebody left’ trigger before the ‘inside temp is higher then 23’ the bedroom curtains will open when the last person left and the inside temp is lower then 23. 0
You should remove the blue line between the inside temperature and the outside temperature, and make i direct connection from the month card to the outside temperature. As shown below.
Then you can check both this conditions.
Then you should use the “AND” card after both theese to if you want both the conditions to be ture or false.
So in your case after the two temperature cards you should draw a blue line from both the cards to an “AND” card and then from the “AND” card to each of the “keep the curtains closed” cards. Then it only opens the curtains if both the conditions are true.
For the opening of the curtains I understand that one of theese conditions needs to be false to open the curtains? Then you can draw a yellow line directly from the temperature cards to each of the “open curtain” cards.
Thx this is indeed the best solution in my eyes. Didn’t think about putting both temperatures apart instead of one after another!
