I’ve been playing with the new shortcuts in iOS 27 and one new feature is to automate a shortcut based on notifications. I tried a flow from Homey to send a push notification to me and created a shortcut to act on it, and it worked. BUT, I’m assuming the notification format coming from Homey isn’t completely compliant as the shortcut can’t read the content of the notification.
If the push notification from homey did work then it opens up a whole new step on potential on apple device automations as well as being able to make homepods speak.
For example, I created a shortcut that ran a command to speak “testing speach” on my homepod in my office if a notification came through from Homey. What I couldn’t do was get it to speak the text in the notification. If we could extract the text from a notification and act on it then it opens up so much.
What can Homey do about it? That sounds like an issue with Apple.
All is possible with Android. Not to nag, just you might need other hardware.
I believe it’s the way the notification is formatted so it is something Homey could change for iOS devices.
In fact this is a Apple beta issue. The information isn’t extracted from any other apps even Apple’s own messages app. It might be available in later updates.
I found a solution to retrieve the text from a Homey push notification in iOS 27.2 Shortcuts.
- Create an automation triggered by a notification from the Homey app.
- Add the Text action.
- Inside the Text action, insert the Notification Message variable (not Title or Subtitle). iOS can’t read Title or Subtitle.
- You can now use the output of the Text action in other actions, such as Speak Text, to have Siri read the notification aloud.
I tested this successfully with Homey push notifications to trigger a focus mode. The notification content was correctly passed through the Text action. Screenshot is in Dutch.
