It would be super useful to be able to invert the zone activity status of sensors, similarly to the “exclude from zone activity” option.
This would be great for modified door sensors that can be used for seat detection et cetera. Otherwise we end up with a seat detector that, when occupied, tells Homey that the zone is inactive
Another solution would be to set zone activity manually in a flow, like “THEN: Set ‘Zone A’ to Active”.
For zone activity this would be useful. For use in a flow it’s easy to achieve with logic cards
In the device advanced-settings for many sensors it is possible to reverse the function:
I’ve seen that Aqara door sensors can reverse their logic. Are you using the advanced settings app to enable it for other stuff?
This was done in the WebApp on my PC, right-click on the device and choose Settings.
This also can be done with the mobile App. ( device … cogwheel… Advanced-setting )
sorry for Dutch text, think it explaines it selves. This is for an Aqara door sensor.
When reversing the function is not possible with your sensor type, you can use a virtual sensor and send reversed commands to it:
