What happened if two instances of a flow or a script are running simultaneously ?
Was it an issue ?
Regards
Was it an issue ?
Regards
What’s your actual question?
Nope unles they depend on each other and therefore give a result your partner didn’t expect and appreciate… then you have an issue ![]()
Hi @GD91 ,
Usually it is not an issue. You have to be careful if you use (global) variables and all variables you declare in your GUI are global.
I tested it for Flows and it seems there is a limit of about 16 different instances before my Homey Pro stopped.
So Flows should nit be too long in time (delay cards), but you should already be careful with using delay. You have to avoid the card waiting while the Homey Pro is shut down.
Just for curiosity. What type of flows or scripts do you want to run parallel?
