Unfortunately, not all plug brands have this function, I have a Qubino plug that does show this function (unfortunately the reading does not show-up, itâs always â (dash)!
Iâm looking for the same functionality. Reset the kWh tracker of the Innr sp120 each day at 0.00. Im not interested in the total usage since the power plug is plugged in. I Just want to know the kWh usage per day.
I have al lot of neo coolcam plugs. Every Sunday they send me the amount of used current in that week per plug. If this is what you are looking for I can show you the flows for that. Just let me know
is it correct I had to type the {{round( part, or is there a better way to do calculations.
Edit: I got it working, by adding the âEnergiemeterâ again in the calculation part. Apparently I used another âEnergiemeterâ. Thanks for the help. I learned a lot how to use these kind of flows.
