[Info] USB Power Supplies and cables (for Homey Pro Early 2023)
:white_check_mark: The NEW HY-PD3 / HY0028 specified with 5.2 V=== / 2.1 A
See the New (Above / connected) and the original 5V=== below.
Please do not use the original anymore for Homey Pro (Early 2023)
If you need to replace it order it here:
PS — in case you want to manually select your power adapter region: Type-C (EU) | Type-A (US) | Type G (UK) | Type I (AU) (Edited to Direct Store Links)
