iNELS Matter over Thread devices available on market
I would like to share with you new Smart home devices that are compatible with the Homey via the Matter (Thread) protocol.
Tested with Homey Pro Early 2023. Works brilliantly.
Made in Czech Republic. For professional electrical installation that will work for many years.
Thank you
Alex
@Alex_Elgart
Thanks! Do you have specific experience with the Inels Matter Double Switch while using the Homey Thread radio?
Hi, yes)
our customers often use a combination of Homey gateway and RFSAI-62B-SL/MT using Thread communication protocol. For now, we are getting only positive responses. Alex
Just got it, unfortunately had no chance to test it
Will post an update as soon as possible
to use this driver directly with Homey, do I need to install an app?
I don’t see one in the Homey app.
Thank you
https://support.homey.app/hc/en-us/articles/12934291420060-Connecting-a-Matter-or-Thread-Device
Would you please verify if this products overheats over time? My main worry is to put something that could potentially cause a fire in my walls. I know it might be overthinking but I really need to know if it overheats (even if it will never catch fire).
Hi Stefano,
thank you for your request. Our products do not overheat under any circumstances. They have built-in protection against overheating and are tested to operate in very high and low temperatures in our accredited laboratory according to SO/IEC 17025:2018
Hello Alex,
When looking at you website, i noticed that the Motion Detector ( Motion detector for ceiling mounting MATTER RFMD-200/MT) is NOT compatible with Homey…
Is this correct because you told in the first message that they all are working with Homey Pro 2023
This is the link to the page
Henk
Hello Henk,
From what I’ve read, it’s not Matter-over-Thread enabled, but just Thread only - which doesn’t work with Homey
