Im having problem with some IKEA stuff and i can´t understand whats happend.
First, the Trådfri button and shortcut button sometimes work and run the flow, and the day after it won´t work and then a day later it start to work.
Then i have a button that runs a good night flow (runs sometimes and sometime not as abow). In the end of the goodnight flow i roll down the fyrtorn blinder. Right now it will not go down with the flow but i can do it from the mobileapp. Earlier It have also change the % of how far i need to go down.
I don´t understand a thing
This is on an HomePro early 2019. When i go to the developsite for zigbee it says that i have 35 devices. (then i have 33 zwave products to homey + some more that i´m import from telldus)
So it can be that i´m starting to have the max capacity of devices, that would be sad.
