IFTTT integration turned off - How can a Homey Flow now run an IFTTT applet
Looking for advice please.
I have installed DC brilliant fans that work via IFTTT.
Current Set UP!
I have Homey Flows “when flow started - run IFTTT applet” then the IFTTT applet will turn on fan.
NOTE: I have different triggers that will start the flow to turn on the fan
Now that IFTTT integration will no longer be supported - how can a Flow now start an IFTTT applet?
Unless I am not understanding properly, the only instructions I can find is how to use an IFTTT trigger to run a Homey Flow via webhooks.
I created a tutorial:
Thank you. Much appreciated.
