I have started to create IFTTT applets for Homey - which is real fun! However, I have two Homeys. Only florws from one Homey shows up on IFTTT. How can I actually connect the other Homey I have on the same account?
Now, I managed to switch between the two Homeys. However, I want to use IFTTT on both. Is the only workaround to create a separate IFTTT account for the second Homey?
It worked with a second IFTTT account, not very elegant though… I see that for instance for Arlo cameras, you can select the hub to connect to. This is not available on Homey, I guess it is a limitation that Athom must address…
