Hello, I have Hue Bridge with Dimmer Switch connected (all set up before I got Homey so I want to keep most things in the Hue app for now). However I want to add “long press” on the Power button in a flow in Homey Pro (the “short press” is used for other things in the Hue app), but the only flow card I have is “power button pressed”, no long press (or short for that matter, only press), no dim up/down, noe Hue/Scene-button. Is this correct? I see there are some posts about this but see no final answer, seems like I can get access to more functions by connecting the dimmer switch directly to Homey Pro? The 4-button dimmer switch could be very useful in my scenario but i only get to play with one switch, and only short press… In practice it has 8 buttons if you add short/long press to all of them.
Any advice from you guys?
It is tempting to buy another switch to do what I want but it seems very stupid when all I need is abilty to trigger an event from long press on the switch I already have.
This flow card should be available for the Dimmer switch; it let’s you select the preferred button:
Thank you! Now we have 4 buttons, however no long press
And as long as the dim-switch is active in the Hue-App also dim up/down are not customizable (fixed to dim up/down). Is there any function in the flow chart that let you add condition “hold button for 2 seconds” or something? I only find delay which doesn’t help in this case.
I am super greatful for all help, awesome!
This post explains how I use a single Flic button to execute multiple actions from a single press. You might be able to use and expand on that technique.
Andy
Like Andy wrote, if it ain’t there, we have to create it
I’ve looked at the specs of the dimmer switch, it doesn’t seem to have a longpress function?
In that case it also won’t be available in the “button” part of the trigger card.
That probably is the same as the physical buttons: on/off/dim+/dim-
I would also love to ask you, if there would be a possibility to add this feature. I recently bought this Hue Dial and I would like to add more functions for a long press card.
Thank you
I am also missing the long-press functionality for the dimmer switch. Curious why it’s not available because it is a standard Hue functionality.
In the Hue mobile app, I don’t see long press events (I held the button but it just says “Button pressed“):
Maybe this is the reason?
