I have my hue bridge connected to homey.
After a short power outage homey shows all devices that are connected via hue with exclamation marks.
Any suggestions on recovery?
What I tried:
Reboot the hue app
Reboot homey
Turn off hue bridge and tturn it on again
Unplug homey and turn it on again
unplug home for >15min and turn it on again
The hue app itself works fine so I think no issue with the bridge
V1 have problems but your version v2 should work. I can’t think of a solution besides using the backup function from Homey, or deleting the Hue app and reinstall. Maybe my fellow community members can help
If I had problems with the connection between Homey and the Hue Bridge, the router was the reason.
But after restarting (PTP) the Hue Bridge the problem was always solved.
Did the Hue Bridge have a fixed IP address?
Maybe restarting the router will help.
I guess that if the Hue Bridge has a fixed IP address and this is stored in the Athom Philips Hue app, then Homey will always use this IP address.
But I had the problem with the router (Fritz Box 7590) that it automatically changed the channel and the connection between Homey and Hue Bridge was interrupted. Since I chose a fixed channel for the 2.4 GHz frequency band, I have no more problems.
What I read on the net is that hue itself does not have fixed IP setting.
And Inforgot to set it in the router…
I guess to make it work again its enough to change in the router the hue IP to fixed and set it to the correct IP.
But what is thenIP homey is looking for???
