I cannot add the Philips Hue dimmer switch to my Homey. Homey find everything else, my lights and plugs. How do I add my dimmer switch to Homey? The dimmer working fine in my Hue-app, so I know it´s working ![]()
Best Regards
Daniel
Best Regards
Daniel
I have The same problem
Thanks
I have the same problem. Dimmer switches are present in the hue app/bridge but can’t be found by homey.
Do you have a Homey Pro? Which model dimmer switch exactly? Is it mentioned on the app page as being supported?
The dimmer switch v2 is supported (which is the one if have). I have a Homey pro.
ps: i tried to install the device in the homey pro app using “Philips Hue”! I know i can look for it in Philips Hue without the bridge, but then i would have to reset the dimmers. (i rather not)
If Homey can’t find it while they are said to be supported, you should contact the app developer.
My bad, dimmers where there in the app.
