How to install aqara m3 hub to homey pro
Is there possibilty to use Aqara M3 Hub in Homey pro 2023
No that is not possible.
It does, according to Aqara:
I am new as well, but I was planning on using the Aqara M3 Siren, but Homey is not recognizing the Aqara M# Bridge. Does anyone have a solution?
You don’t acually connect a bridge as a device.
When you’re using an Aqara bridge, certain devices paired to it, should become available as Matter devices.
What happens when you search for new Matter devices with Homey?
Yes, you are correct about Aqara Matter devices now appear, but I thought I would be able to use the siren that comes with the Aqara Hub. Is there any way to accomplish that. I do truly appreciate your help.
I see. I can’t help you with that, sorry.
Hi everyone,
I have the Homey Pro and would like to integrate one of the new Aqara V1 EU switches. Unfortunately, this switch does not appear in the Homey app and therefore cannot be configured directly.
My question: Would buying the Aqara M3 Matter Hub help, and could I configure the switch through it? Would I then be able to integrate the switch into Homey Pro? If so, what functions would I be able to control?
Thanks in advance for your help!
Best regards, Uwe
