How to disable Sonoff ZBMINI in the Homey app so they can only work with flows
I have some ZBMINI switches Sonoff.
One of them is doing stuff that I need to validate.
So I want to disable the ZBMINI ON/OFF button in the Homey App (devices), so I can only use it within flows where I can add validations with variables…
Please help!
Can’t find it
I am not sure whether this is possible. The is an ‘Always On’ setting in the device’s settings page in Homey, which blocks the off action of the tile/button in Homey. However I assume that you will also lose the option to set the on/off state of the switch via a flow. You’ll have to try it.
Thanks @SunBeech
It’s not possible.
The switch is connected to the machine and sometimes (no reason) it switches the machine on when we are not there. It’s meant to start the machine on demand, not just when it decides to start… Maybe I need to replace the NODON relay switch with another brand?
(just found out it’s not the ZBMINI here, I have tens of each)
