Anyone know how to hook this up to homey?
Am running it through HA now with a zigbee board 4 relais, and mqtt….but want to connect to homey if possile.
Regards
Is it a Tuya ZigBee relay board? In that case, you can use the Tuya ZigBee app
This is the only ‘Alab’ device in Z2M, unsure if it’s a Tuya whitelabel;
You can always ask Dylan if this unit can be added to his universal Tuya zigbee app (work in progress), but, most probably you’ll have to purchase it on beforehand, because the dev needs the interviewed zigbee data in order to build a driver;
Copy this link in your post as well:
Without app, it’s shows as a single relay:
Sharp eye!! I totally didn’t see that! I would only need 1 relay to work, so that would be enough for me!
