Homeyscript variable gets filled with text instead of value
var waterContractPeriodIndex = global.get('waterContractPeriodIndex');
console.log('waterContractPeriodIndex is: '+waterContractPeriodIndex)
var powerContractPeriodIndex = global.get('powerContractPeriodIndex')
console.log('powerContractPeriodIndex is: '+powerContractPeriodIndex)
test = (sort[count] +'ContractPeriodIndex'+'['+(currentMonth -1) +']');
console.log('waterContractPeriodIndex from test is: '+test);
test2 = waterContractPeriodIndex[0];
console.log('waterContractPeriodIndex from test2 is: '+test2)
This is the result:
waterContractPeriodIndex is: 2023,2023,2024,2024,2024,2024,2024,2024,2024,2024,2024,2024
powerContractPeriodIndex is: 2023,2023,2023,2023,2023,2023,2023,2024,2024,2024,2024,2024
waterContractPeriodIndex from test is: waterContractPeriodIndex[0]
waterContractPeriodIndex from test2 is: 2023
In the test i get the name of the variable but not the value, when i enter the name of the variable in test2 it works. How can i make it work in test
console.log('waterContractPeriodIndex from test is: '+eval(test));
thx worked at once
