I have a HomeyScript with only one line of code:
tag("AvgPrice", "Test");
When running the script, it creates a flow tag but the value is always “-” when trying to reach it from the advanced flow.
Any ideas why?
I have tried with both strings and numerical values but both of them just shows up as a “-”. (See to the right in the attached image)
Thanks!
better use this format: await tag('neerslag', data);
Tried it, but that did unfortunately not help.
await tag('Test123', 123);
Still just shows up as a “-”. Weird thing is that it marks the flow tag green if I enter a string, and blue if I enter an integer.
Caseda
4
Are you really sure it is -? and not just a never implemented feature in the web app? (hint hint)
JPe4619
5
How does your flow look like? Please share if you want help.
Like Caseda hinted (I think), just use the tag in a timeline notification card → THEN you’ll see its value.
Not in the selection list.
That’s b/c green is used with string tags, and blue for num tags
Here’s a screenshot of the flow. All of the HomeyScript values are “-” but displays fine from other apps.
Like I proposed, send the tag with a notification card. Does it send a “-”?
JPe4619
9
The flow must have RUN at least once, before the value is visible.
( this is done on my HomeyPro(early2016) )
Just like JPe4619 said, the solution was to run the script once in the advanced flow and then the valued showed up!
Thanks alot!
