Hi, i have just upgraded to Homey v 5.0.0-rc.38.
After the upgrade, i reset the zigbee network.
I could then include/connect my “aqara temp” sensor and “aqara gyro switch” without any problems.
When i wanted to add the “Aqara cube”, it seems to fail.
When i press the button short: short blink(in manual it says range test, and it should send a signal to aqara hub to say something on speaker)
When i longpress it for 15 seconds: the first 3 seconds, the blue led is lit up, and then is off for the rest of period
The manual says that if you hold the button for 5 sec, it will reset the device.
I have tried to reset the device several times, removed the battery, and restart homey, etc…
I don’t have a zigbee repeater, and also havent connected other zigbee devices than the ones mentioned here.
This is something with like push the button untill the led blinks 3 times?
When u succeed (Homey will tell u it’s being added) keep pressing the button every 2 seconds for a short time.
So, press the button untill the led blinks 3 times and let go. Every 2 seconds, push the button 1 time untill ur done (Homey will tell u again) and it’s not easy!
Keep the cube near Homey while ur doing this. And 2 meters is not close, 10cm is!
I have it 20 cm away from the homey.
if you read my post, you can see that the led isn’t blinking…EVER…
So, no blinking at all…
PS: This is an Aqara cube, and not the MI cube. Not sure what or if there is any difference.
I also talked with the developer of the app, and he told me that Aqara cube also should work with the app.
Holding it longer is a reset. I don’t own one, but are you sure you are not pushing it too long? Have you tried releasing the button when it lights up after 3 secs? (and pressing it shortly every 2 secs to keep it alive).
I’m having the same issue.
I removed it when I first installed v5 as was having ZigBee issues so wanted to try and re-add something and now can’t connect it
There is only one good way in telling “battery is fine” and that’s to measure it like Joka says.
Saying the battery is fine because it’s new and not been used is just an assumption!
