Hi Team,
my Pro updated three days ago automatically (have switched that off now %-) to 5.0.0 and Osram Lightify (ZigBee) to 1.4.5.
I don´t have a clue what version it was before - @Athom: Where can I check that ?
Since then the lights didn´t reconnect. I paired them again, they are recognized but don´t respond to on/off/anything.
- Known issue ? When will that be fixed ?
@Athom: PLEASE do proper testing / staging
@Athom: PLEASE enable easy roll-backs to earlier versions (of Homey firmware and apps) !!!
Any feedback is highly appreciated !
Tom
If you want a direct answer from athom, you should asked them it directly. They wont repond on the forum, as its a community forum.
As Roy answered, Athom will not answer any questions here, so you have to contact them directly.
Did you try already a PTP (Pull the Plug of Homey for about 15 Min.)?
Thanks, folks. I didn´t try it for 15 minutes. Resetted the baby by turning it upside down…
And thanks for the hint to contact them directly - I didn´t find a forum to do so… Any hint ?
PTP didn´t work. Only the Ledvance spots don´t work. They connect, but can´t be controlled…
Do you guys have a hint to roll-back apps or Homey ?
Thaaaanks, Tom
For everybody interested…
Problem solved: Don´t use the Osram App, the Ledvance Smart + App did the trick, all up and running !
