Homey SHS - Trigger WebHooks locally?
Did anybody already figure out how to trigger WebHooks locally (not using the cloud) when self-hosting Homey? I have Homey up and running in Podman and I pretty much fully migrated all my 60 devices and 50 Flows, that is the one and only issue I have left.
I tried what worked before:
http://IP/webhook?event=TAG
I also checked the support article:
https://support.homey.app/hc/en-us/articles/18292876827548-Using-Webhooks-with-Homey
Any hints would really welcome!
Use the correct port, as mentioned in the fine documentation.
Thank you so much, that was exactly the hint I needed :heart_eyes: . Since I have everything on the default ports, this works:
http://IP:4859/webhook?event=TAG
Thanks @robertklep
@chixxi1 Me too… I got stuck reading:
Using Webhooks with Homey – Homey Support
Homey Pro (Early 2023) & Homey Pro mini
http://ip-of-homey/webhook?event=my_event&tag=my_tag
Homey Pro (2016 — 2019)
http://ip-of-homey/api/manager/logic/webhook/<my_event>?tag=my_tag
Just note that the GET webhook cannot pass #, end of lines and icons like :fire: in the text.
MQTT would do it, but I do not have the memory to install it :slight_smile:
Solved with a Gemini HomeyScript encodeURL as per below (there is no need to decode on the receiving side).
// EncodeURL
// Script Version: 2.0
// Purpose: URL Encode text and return as a LOCAL tag
// 1. Get the argument (safely handle empty input)
let inputString = args[0];
if (inputString == null) {
    inputString = "";
// 2. Encode the string (newlines -> %0A, spaces -> %20)
let encodedString = encodeURIComponent(inputString);
// 3. RETURN the string
// This places the value into the local "Result" tag of the flow card.
// We explicitly wrap it in String() to ensure the type is correct.
return String(encodedString);
