I have bought a mini PC and installed Ubuntu and Docker to run Homey SHS. I have one major problem: if I follow the instructions on https://support.homey.app/hc/en-us/articles/24010537261980-How-to-install-Homey-Self-Hosted-Server-with-Docker-on-Linux But with network_mode: host, I dont get a port. I see my container in Docker, with no port(s) so it won’t work. If I remove and force the port with something like this:
–name homey-shs
–restart=always
-p 4859:4859
-p 4860:4860
My Homey SHS works and I can add the IP / setup the android app and there’s a lot that works: adding Hue lights, installing apps and importing devices etc. There are als some things that will not work: adding the Homey Bridge or finding Google Cast (Chromecasts, Nest Hubs) devices for example… I cannot get it working with network_mode: host and not everything works without network_mode: host. It’s driving me crazy! Anyone has idea’s? Would be apprenticed!
Hi thanks for your reply. But this is basically the same right? Both use Docker, one with a yaml/docker compose and one directly. But I have the same issue regarding network_mode: host
I run SHS on a Lenovo SFF, Ubunutu server 24.0.4 LTS
My compose file:
services:
homey-shs:
image: ghcr.io/athombv/homey-shs:latest
container_name: homey-shs
restart: unless-stopped
network_mode: host
privileged: true
volumes:
- ~/.homey-shs:/homey/user
uname -a
Linux homey-shs 6.17.0-14-generic #14-Ubuntu SMP PREEMPT_DYNAMIC Fri Jan 9 17:01:16 UTC 2026 x86_64 GNU/Linux
Docker version 29.3.0
Are there any hints in th elog output when the container starts up? (docker run without the -d will spew it all to the terminal screen). Also logs are in the .homey-shs directory.
Not sure what you mean exactly, but you can view the logs by executing this command (in a second terminal):
$ docker compose -f homey-shs.yml logs --follow
As per KB article https://support.homey.app/hc/en-us/articles/24010537261980-How-to-install-Homey-Self-Hosted-Server-with-Docker-on-Linux
No sure what you mean either.
To verify if docker container is running as expected i usually use docker ps. It will show each docker container status (and some other details).
To get docker logs from a container docker logs <container name>.
yes, better choices to use ‘docker logs’ if the container is already running. (–follow is aslo a good option to keep watching) But that only show recent stuff.
The full log file is actually also visible in ~/.home-shs/logs if you want to root around finding specific things.
True, but it shows everything from the start on when I start that “follow” command prior to the container start.
I have a similar issue. From my HPE 2019 I can’t reach SHS by using Homesh controller APP on my HPE2019. Viceversa it is working fine: from my SHS i can reach HPE2019 by using Homesh controller APP on my SHS. Did you have any suggestion?
The error that rises on my HPE2019 side is “connect ECONNREFUSED :80”, it happens when I try to connect to the Homesh Satellite APP on SHS.
Please could anyone help me?
I’d first try the HomeyLink app instead.
Otherwise, you probably have to change the default port temporary from 4859 to 80 to see if it connects;
Make sure there’s no other local web server running on port 80.
SHS in Docker on TerraMaster F2-223 (TOS 7, Docker Manager): every app crashes immediately on start.
Error from container logs:
CreateClientError: ManagerDrivers.getDrivers is not a function
at SDK.createClient (/app/packages/homey-local/lib/AppProcess/…)
Homey [err][ManagerAppsLocal] Error Starting: App Crashed
Exit Code: 1
SHS itself is healthy — discovery, login, app store browsing all work, trial active. Only the app spawn step fails.
Already tried, none resolved it: restart, rebuild, fresh image pull, full nuclear reinstall (deleted project + image + volume + Athom account instance), HOMEY_LOCAL_ADDRESS env var
Anyone seen this ManagerDrivers.getDrivers error
Hi All,
Just tried to follow the install in docker on Ubuntu.
I think it is running as I get the blurb that says it is…
However the Android App says it has “1 Self Hosted Server found…” at the correct IP address but then timer whirrs and nothing happens. With manual I get “unable to connect to your Self Hosted Server”.
EDIT - I had started my thread and then realised it was a firewall blocking the port 4859 and 4860.
I will still post it if this is useful to other newbies.
Dave
If it matters - Server HP box 16Gb RAM, a few Tb of disc space, Ubuntu Server 24.04.4 LTS
A backup-and-update script that runs flawlessly.
It’s not usable as-is , because it assumes specific mount points and directory layouts.
#!/usr/bin/env bash
# sudo ./backUpdate_Pi5_SHS.sh
set -Eeuo pipefail
# CONFIGURATION
DATE="$(date +%Y%m%d-%H%M%S)"
MOUNT="/mnt/pi5-T7B"
BACKUP_DIR="$MOUNT/Backup4/Pi5_Backup"
INFO_DIR="$BACKUP_DIR/Backup_INFO"
KEEP=31
LOG="/var/log/backup-pi5-opi.log"
USER_NAME="YOUR_USERNAME"
USER_HOME="/home/$USER_NAME"
HOMEY_CONTAINER="homey-shs"
HOMEY_IMAGE="ghcr.io/athombv/homey-shs"
HOMEY_DATA="$USER_HOME/.homey-shs"
DOCKER_DIR="$USER_HOME/homey-shs"
SCRIPTS_DIR="$USER_HOME/scripts"
COMPOSE_DIR="$USER_HOME/homey-shs"
# LOGGING
sudo mkdir -p "$(dirname "$LOG")"
sudo touch "$LOG"
sudo chmod 600 "$LOG"
exec > >(tee -a "$LOG") 2>&1
log() {
printf '%s - %s\n' "$(date '+%Y-%m-%d %H:%M:%S')" "$*"
step() {
printf '\n[%s] STEP %s/9 - %s\n' "$(date '+%H:%M:%S')" "$1" "$2"
fail() {
log "ERROR: $*"
exit 1
# RESTART CONTAINERS ON EXIT OR ERROR
HOMEY_WAS_RUNNING=0
restore_containers() {
local rc=$?
log "Running cleanup..."
if [[ "$HOMEY_WAS_RUNNING" == 1 ]]; then
if docker start "$HOMEY_CONTAINER" >/dev/null 2>&1; then
log "Homey SHS restarted"
else
log "WARNING: Homey SHS could not be restarted"
fi
fi
if [[ "$rc" -eq 0 ]]; then
log "=== MAINTENANCE COMPLETE ==="
else
log "Maintenance terminated with error code $rc"
fi
exit "$rc"
trap restore_containers EXIT
# STARTUP CHECKS
step 1 "Startup checks"
log "=== MAINTENANCE START ==="
mountpoint -q "$MOUNT" || fail "$MOUNT is not mounted"
sudo mkdir -p "$BACKUP_DIR" "$INFO_DIR"
command -v docker >/dev/null 2>&1 || fail "docker is not available"
[[ -d "$HOMEY_DATA" ]] || fail "Homey SHS directory does not exist: $HOMEY_DATA"
# COLLECT OPTIONAL DIRECTORIES
step 2 "Collect optional directories"
OPTIONAL_PATHS=()
for path in "$DOCKER_DIR" "$SCRIPTS_DIR" "$COMPOSE_DIR"; do
if [[ -d "$path" ]]; then
if [[ ! " ${OPTIONAL_PATHS[*]} " =~ " ${path} " ]]; then
OPTIONAL_PATHS+=("$path")
fi
log "Optional directory found: $path"
else
log "Optional directory skipped: $path"
fi
done
# PRESERVE ORIGINAL CONTAINER STATUS
step 3 "Preserve container status"
if docker inspect "$HOMEY_CONTAINER" >/dev/null 2>&1; then
if [[ "$(docker inspect -f '{{.State.Running}}' "$HOMEY_CONTAINER")" == "true" ]]; then
HOMEY_WAS_RUNNING=1
fi
else
log "WARNING: container does not exist: $HOMEY_CONTAINER"
fi
# BACK UP SYSTEM CONFIGURATION
step 4 "Back up system configuration"
sudo tar \
--ignore-failed-read \
--xattrs \
--acls \
--numeric-owner \
-czf "$BACKUP_DIR/system-$DATE.tar.gz" \
-C / \
etc \
boot \
-C "$USER_HOME" \
.ssh \
.config
log "System configuration saved"
# SAVE SYSTEM INFORMATION AS TXT
step 5 "Save system information"
echo "=== DATE ==="
date
echo
echo "=== HOSTNAME ==="
hostnamectl 2>/dev/null || hostname
echo
echo "=== KERNEL ==="
uname -a
echo
echo "=== OS ==="
cat /etc/os-release
echo
echo "=== DISKS ==="
lsblk -f
echo
echo "=== MOUNTS ==="
findmnt
echo
echo "=== NETWORK ==="
ip addr
ip route
echo
echo "=== WIFI ==="
iw dev 2>/dev/null || true
nmcli device status 2>/dev/null || true
nmcli connection show 2>/dev/null || true
echo
echo "=== ENABLED SERVICES ==="
systemctl list-unit-files --state=enabled 2>/dev/null || true
echo
echo "=== ROOT CRONTAB ==="
crontab -l 2>/dev/null || true
echo
echo "=== USER CRONTAB: $USER_NAME ==="
sudo -u "$USER_NAME" crontab -l 2>/dev/null || true
} | sudo tee "$INFO_DIR/system-info-$DATE.txt" >/dev/null
sudo chmod 644 "$INFO_DIR/system-info-$DATE.txt" 2>/dev/null || true
# DOCKER INFORMATION IN Backup_INFO
step 6 "Save Docker information"
docker ps -a | sudo tee "$INFO_DIR/docker-containers-$DATE.txt" >/dev/null
docker image ls --no-trunc | sudo tee "$INFO_DIR/docker-images-$DATE.txt" >/dev/null
docker volume ls | sudo tee "$INFO_DIR/docker-volumes-$DATE.txt" >/dev/null
docker network ls | sudo tee "$INFO_DIR/docker-networks-$DATE.txt" >/dev/null
docker inspect \
"$HOMEY_CONTAINER" \
2>/dev/null \
| sudo tee "$INFO_DIR/docker-inspect-$DATE.json" >/dev/null || true
sudo chmod 644 "$INFO_DIR/docker-containers-$DATE.txt" 2>/dev/null || true
sudo chmod 644 "$INFO_DIR/docker-images-$DATE.txt" 2>/dev/null || true
sudo chmod 644 "$INFO_DIR/docker-volumes-$DATE.txt" 2>/dev/null || true
sudo chmod 644 "$INFO_DIR/docker-networks-$DATE.txt" 2>/dev/null || true
sudo chmod 644 "$INFO_DIR/docker-inspect-$DATE.json" 2>/dev/null || true
# STOP HOMEY SHS
step 7 "Stop Homey SHS for backup and update"
log "Stopping Homey SHS..."
docker stop "$HOMEY_CONTAINER" >/dev/null 2>&1 || true
fi
# HOMEY SHS BACKUP AND UPDATE
step 8 "Back up and update Homey SHS"
sudo tar \
--xattrs \
--acls \
--numeric-owner \
-czf "$BACKUP_DIR/homey-shs-$DATE.tar.gz" \
-C "$(dirname "$HOMEY_DATA")" \
"$(basename "$HOMEY_DATA")"
log "Homey SHS backup saved"
log "Fetching new image..."
docker pull "$HOMEY_IMAGE"
log "Removing container if present..."
docker rm "$HOMEY_CONTAINER" >/dev/null 2>&1 || true
log "Starting new container..."
docker run \
--name "$HOMEY_CONTAINER" \
--network host \
--privileged \
--detach \
--restart unless-stopped \
--volume "$HOMEY_DATA":/homey/user/ \
"$HOMEY_IMAGE"
sleep 5
if docker ps --format '{{.Names}}' | grep -qx "$HOMEY_CONTAINER"; then
log "Homey SHS running again"
else
fail "Homey SHS does not appear to have started correctly"
fi
# CREATE AUTOMATION ARCHIVE
step 9 "Create automation archive"
if [[ "${#OPTIONAL_PATHS[@]}" -gt 0 ]]; then
TAR_ARGS=()
for path in "${OPTIONAL_PATHS[@]}"; do
TAR_ARGS+=(
-C
"$(dirname "$path")"
"$(basename "$path")"
done
log "Automation sources: ${OPTIONAL_PATHS[*]}"
sudo tar \
--xattrs \
--acls \
--numeric-owner \
-czf "$BACKUP_DIR/automation-files-$DATE.tar.gz" \
"${TAR_ARGS[@]}"
log "Archive OK: automation-files-$DATE.tar.gz"
else
log "No optional directories found; skipping automation-files archive"
fi
# VERIFY AND CLEAN UP ARCHIVES
log "Checking backup files..."
REQUIRED_ARCHIVES=(
for archive in "${REQUIRED_ARCHIVES[@]}"; do
[[ -s "$archive" ]] || fail "Empty or missing archive: $archive"
if tar -tzf "$archive" >/dev/null 2>&1; then
log "Archive OK: $(basename "$archive")"
else
fail "Invalid tar archive: $archive"
fi
done
if [[ -f "$BACKUP_DIR/automation-files-$DATE.tar.gz" ]]; then
tar -tzf "$BACKUP_DIR/automation-files-$DATE.tar.gz" >/dev/null \
|| fail "Invalid automation archive"
fi
log "Cleaning up old tar.gz backups..."
cleanup_category() {
local pattern="$1"
local directory="$2"
mapfile -t OLD_FILES < <(
find "$directory" \
-maxdepth 1 \
-type f \
-name "$pattern" \
-printf '%T@ %p\n' |
sort -rn |
tail -n +$((KEEP + 1)) |
cut -d' ' -f2-
for file in "${OLD_FILES[@]}"; do
[[ -f "$file" ]] || continue
rm -f -- "$file"
log "Deleted: $file"
done
cleanup_category "system-*.tar.gz" "$BACKUP_DIR"
cleanup_category "homey-shs-*.tar.gz" "$BACKUP_DIR"
cleanup_category "automation-files-*.tar.gz" "$BACKUP_DIR"
cleanup_category "*.txt" "$INFO_DIR"
cleanup_category "*.json" "$INFO_DIR"
log "Backup + update completed successfully"
there is still some Dutch comment in the version above, translation below:
#!/usr/bin/env bash
# sudo ./backUpdate_Pi5_SHS_EN.sh
set -Eeuo pipefail
# CONFIGURATION
KEEP=31
# LOGGING
sudo touch "$LOG"
log() {
step() {
fail() {
log "ERROR: $*"
exit 1
HOMEY_WAS_RUNNING=0
local rc=$?
else
fi
fi
else
fi
exit "$rc"
# STARTUP CHECKS
OPTIONAL_PATHS=()
fi
else
fi
done
HOMEY_WAS_RUNNING=1
fi
else
fi
sudo tar \
--xattrs \
--acls \
--numeric-owner \
-C / \
etc \
boot \
-C "$USER_HOME" \
.ssh \
.config
echo "=== DATE ==="
date
echo
echo
uname -a
echo
echo "=== OS ==="
cat /etc/os-release
echo
lsblk -f
echo
findmnt
echo
ip addr
ip route
echo
echo "=== WIFI ==="
echo
echo
echo
docker inspect \
2>/dev/null \
# STOP HOMEY SHS
fi
sudo tar \
--xattrs \
--acls \
--numeric-owner \
docker run \
--network host \
--privileged \
--detach \
"$HOMEY_IMAGE"
sleep 5
else
fi
TAR_ARGS=()
TAR_ARGS+=(
-C
done
sudo tar \
--xattrs \
--acls \
--numeric-owner \
"${TAR_ARGS[@]}"
else
fi
REQUIRED_ARCHIVES=(
else
fi
done
fi
local pattern="$1"
find "$directory" \
-maxdepth 1 \
-type f \
-name "$pattern" \
sort -rn |
cut -d' ' -f2-
rm -f -- "$file"
done
No-mind
October 17, 2026, 4:37pm
55
I have the docker container installed and connected to the Android app. When I open the interface from a browser on Windows, my credentials are not accepted?
First create a local account.
Please search for howto @ support.homey.app
No-mind
October 18, 2026, 3:20pm
57
I tried but the Android client does not accept a second login. And the admin account cannot be promoted to also be a local account. Do I need a 2nd Android device to be able to create a new account?
Please read this kb article. You’ll need to use my.homey.app
No-mind
October 18, 2026, 8:18pm
59
I don’t have a Homey Pro. I have a selfhosted docker server and an android app that connects to it. But in the app I can’t grant users local access. The interface is not the same. I also can’t add another user because the app doesnot allow a 2nd user using the app on Android.
OK, you somehow can’t, or just don’t, want to read info aimed for SHS (and yes, it’s also applicable to Homey Pro).
A detail from the article I linked to, and as screenshotted as well:
I’m out.
