Hi all,
I’m running Homey Self-Hosted Server (SHS) in VMware Workstation and I’m running into a disk space issue.
Homey is currently running:
- Homey SHS: 13.5.0
- VMware Workstation
- Virtual disk: 64 GB
- Linux root partition: only 7.5 GB
- Filesystem: ext4
/root/.homey-shs: only about 165 MB- Docker itself reports only one active container.
The problem is that almost all disk usage is coming from containerd:
/var/lib/containerd ~5.0 GB
/var/lib/containerd/.../overlayfs ~4.7 GB
df -h shows the root filesystem around 95–97% full.
I already tried the normal Docker cleanup commands:
docker container prune -f
docker image prune -a -f
docker system prune -a -f
apt-get clean
journalctl --vacuum-time=7d
Docker currently reports:
Images: 1
Active: 1
Reclaimable: 0 B
Containers: 1
Active: 1
Reclaimable: 0 B
However:
du -sh /var/lib/containerd/io.containerd.snapshotter.v1.overlayfs
still reports:
4.7G
I also noticed that containerd has a large number of snapshots/container objects:
ctr -n moby containers ls | wc -l
115
but:
ctr -n moby tasks ls
shows only one running task.
The snapshot usage shows several large layers, approximately:
~699 MiB
~698 MiB
~697 MiB
~695 MiB
~685 MiB
plus several layers around 249–250 MiB.
The current Homey container is:
ghcr.io/athombv/homey-shs:latest
and Docker only sees this one container:
homey-shs
My VMware VMDK is already 64 GB, but the Linux partition is only 7.5 GB:
/dev/sda 64G
├─/dev/sda1 7.5G ext4 /
├─/dev/sda2 1K
└─/dev/sda5 480M swap
So I have plenty of unused space on the virtual disk, but the root partition hasn’t been expanded.
My questions
- Is there a recommended/supported way in SHS to clean old containerd/overlayfs snapshots?
- Why does
containerdhave ~4.7 GB of overlayfs data while Docker reports only one active image/container? - Are these old Homey image layers safe to remove using
ctr, or should SHS/containerd handle the cleanup automatically? - Is there a recommended procedure to expand
/dev/sda1from 7.5 GB to use the existing 64 GB virtual disk? - Is there anything specific to Homey SHS I should do before modifying the partition layout?
I don’t want to manually delete anything from:
/var/lib/containerd/io.containerd.snapshotter.v1.overlayfs/
because I don’t want to break the Homey installation.
Any advice from someone familiar with the SHS/containerd setup would be greatly appreciated.
Thanks!
