From earlier in this topic:
No. You would need to do redo everything. There is no migration of settings either way.
Nevermind, installed it on Debian nuc and now works flawlessly.
just installed Homey self hosted server on my Mac M2 and it worked fine. But for some reason I got two servers in the account so I removed both and did a new install. But now it does not find it in the phone app and if I type the IP adress in manually it gives me the error code: Not in set up mode then it creates a new SHS on my account that I cannot access. Any ideas on how to fix this?
Fixed it!
Deleted the whole application and everything out of my finder folder.
Next I opened finder. selected in the top of my screen: Go ā Go to map and paste:
~/Library/Containers/app.homey.shs.Homey-Self-Hosted-Server/Data/Library/Application Support/Homey Self-Hosted Server
Next what I did was deleting the Data folder.
Downloaded the application again and reinstalled it.
Working fine again!
Would greatly appreciate configurable RAM usage, as it stands right now Iām wasting 3+GB of precious Mac RAM
. One day I hope to exceed 4GB limit, but right now it would be awesome to claim some RAM back. Also could be cool if it was adjustable via a flow?
Iām trying to update my Homey Pro self-hosted server on my Mac Mini with latest MacOS. Iām currently running version 12.11.0 and got a notification that there is a new update last night.
When I click ācheck for updatesā in the Mac app, it says Homey Self-Hosted Server 12.12.0 is now available - you have 12.11.0. Would you like to download it now?
In the release notes I see that thereās also v12.13.0 and v13.0.0 available.
When I click āinstall updateā, it will download and then error. Sometimes I get to around 400mb, sometimes it stops at 205,9mb. Whatās going on?
Does it perhaps try to download v13.0.0 and expects v12.12.0 and therefore bugs out?
Whatās the error?
This topic might better be merged with the Homey SHS on MacOS Megathread
If youāre adventurous you could have a look in the logs (via āConsoleā app on the Mac and search for āHomey Self-Hosted Serverā). Otherwise I would suggest to reach out to homey support for further investigation.
Cant post it here because I can only reply to 2 people ![]()
Tried to open a support ticket, but I canāt:
āAs much as weād love to help, we focus on general support and canāt assist with custom use-cases. For tailored advice, visit the Homey Community forum, where experienced users might be able to help.ā
Not having a good time at the moment.
That makes you wonder whatās custom about updating homey selfhosted server.
Keep Homey Self-Hosted Server Running 24/7 on macOS (Free, Built-in Solution)
Running Homey Self-Hosted Server on a Mac Mini is great ā but the app can unexpectedly quit, leaving your home automations dead until you notice. Hereās how to fix that permanently using launchd, a completely free built-in macOS tool. No third-party apps, no subscriptions.
What it does:
- Automatically restarts Homey within 60 seconds if it quits or crashes
- Starts Homey automatically on every login/reboot
- Runs silently in the background, 24/7
Step 1 ā Create the LaunchAgents folder (if needed)
Open Terminal and run:
mkdir -p ~/Library/LaunchAgents
Step 2 ā Create the watchdog config file
nano ~/Library/LaunchAgents/com.homey.watchdog.plist
Paste this content:
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN"
"http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>Label</key>
<string>com.homey.watchdog</string>
<key>ProgramArguments</key>
<array>
<string>/usr/bin/open</string>
<string>-W</string>
<string>/Applications/Homey Self-Hosted Server.app</string>
</array>
<key>KeepAlive</key>
<true/>
<key>RunAtLoad</key>
<true/>
<key>ThrottleInterval</key>
<integer>60</integer>
<key>StandardOutPath</key>
<string>/tmp/homey-watchdog.log</string>
<key>StandardErrorPath</key>
<string>/tmp/homey-watchdog-error.log</string>
</dict>
</plist>
Save with Ctrl+O ā Enter ā Ctrl+X
What each key does:
KeepAlive: trueā restarts the app whenever it stopsRunAtLoad: trueā starts the app at loginThrottleInterval: 60ā waits 60 seconds before restarting (prevents crash loops)StandardOutPath / StandardErrorPathā saves logs to/tmpfor debugging
Step 3 ā Activate the watchdog
launchctl load ~/Library/LaunchAgents/com.homey.watchdog.plist
Thatās it! ![]()
Verify itās working
launchctl list | grep homey
You should see two lines like this:
87287 0 com.homey.watchdog
87288 0 application.app.homey.shs.Homey-Self-Hosted-Server.10025487.10025611
As long as the first column shows a number (not a -), both the watchdog and Homey are running.
In System Settings > General > Login Items & Extensions, youāll see Athom B.V. listed ā thatās Homey Self-Hosted Server. Athom is the company behind Homey, so this is correct.
Quick Reference ā All Commands
| Action | Command |
| Check status | launchctl list | grep homey |
| View output log | cat /tmp/homey-watchdog.log |
| View error log | cat /tmp/homey-watchdog-error.log |
| Pause watchdog (for updates) | launchctl unload ~/Library/LaunchAgents/com.homey.watchdog.plist |
| Resume watchdog | launchctl load ~/Library/LaunchAgents/com.homey.watchdog.plist |
| View plist file | cat ~/Library/LaunchAgents/com.homey.watchdog.plist |
Pausing for Updates or Maintenance
When updating Homey, unload the watchdog first ā otherwise it will immediately relaunch the app after you quit it.
Pause:
Resume after update:
Typical update workflow:
- Unload the watchdog (command above)
- Quit Homey Self-Hosted Server
- Perform your update
- Reload the watchdog (command above)
- Verify:
After a Reboot
Nothing manual needed. macOS loads the watchdog automatically at every login.
Make sure:
- Auto-login is on: System Settings > Users & Groups > Automatically log in as
- Sleep is off: System Settings > Energy > Prevent automatic sleeping when display is off
Summary
Free ā uses macOS built-in launchd
Automatic restart within 60 seconds of any crash
Starts on every login/reboot
Easy to pause for updates and resume
No third-party apps needed
Hope this helps MacOS Homey Self-Hosted users!
Like it does for me, finally can start using the Homey Self Hosted Server
How is the experience running Homey SHS on a Mac Mini now? Are there still RAM limitations? Stability issues? I have a 2023 Homey Pro with lots of devices and automations and sometimes those automations donāt always run reliably. Iām suspecting my 2gb of RAM might be to blame. So my solution is to move to a SHS set up. I have a TrueNAS sever right now and will soon be adding an M4 Mac Mini. The thinking is keep my media streaming and heavy data back-up (Non-Homey related) on the TrueNAS server, and move most of the process-heavy stuff to the Mac Mini, including an instance of Homey SHS and Home Assistant. Homey runs 95% of the automations in my smart so the task of moving everything from the 2023 Pro to a SHS is going to be very time consuming and daunting since there is a not (yet) and option for backing up my Pro and then restoring to the SHS, so needless to say, itās a thing I only want to do once!
So my question is this: Is the Mac Mini the way to go for hosting Homey? Or would I be better off leaving the 2023 Homey Pro in control? Maybe the 2gb of RAM on my Pro is not the issue? Maybe the issue is more the hobby-grade nature of smart homes? I donāt know. Iām willing to try just about anything. I enjoy this stuff, but the wifeās patience with this are beginning to thin.
Thanks
Maybe itās possible to narrow it down:
- Is it app related?
- Disable a few RAM hungry, less important apps for a while
- Dynamically enable apps only when needed: Like my plant sensors need to report once a day ā so I enable the app per flow, for only half an hour at night
- Is it protocol related (like, for example, z-wave or cloud devices)?
- Is it event related (sun, time)?
- Maybe itās sensor related? Try replacing the batteries, even if Homey āsaisā thereās enough juice left (it really is just a gadget, not a battery tester)
- Do you use the Audit app to see whatās (not) happening and when?
Sorry to hear mate, we try our best
So, as far as the reliability aspect; I have been chasing it for a while. For example: I have a bunch of Aqara devices with an Aqara Hub M3. I have tried running all the Aqara devices through the M3 hub then importing them into Homey via Matter. I have also tried moving unreliable devices directly into Homey and bypassing the M3 hub. Iāve tried this with several devices like Hue bulbs, Switchbot stuff, etc. Mixed success overall. Iāve also tried moving some stuff over the Home Assistant as a reliability test bed. Iāve tried adjusting the freq bands of my wifi system to account for interference. Iāve restructured flows and even taken some functions out of more complicated flows and made them their own individual flows. Iāve never actually been able to get my smart to be totally reliable. Sure, Iāll admit that the constant fiddling with it is not always helpful, as my wife likes to mention, but I was just curious if others have seen improvements moving to a beefier system.
I will try disabling some apps here and there, though, to see if that nets any positive results. Not a bad idea. I appreciate the advice.
Are you also using Apple Home?
