Homey read data from Growatt inverter via WiFi dongle
Hi, I’m new here and after 1 year experimenting with Homey Cloud, I now changed to a Homey Pro.
The energy tab is now showing my Growatt inverter by reading cloud data, with quite a delay.
I’ve read and saw a manual how to install a Modbus to have a local wired connection.
Is it possible to setup a local - wifi connection with Homey Pro receiving data from my Growatt inverter?
(My Growatt has a std. wifi Dongle)
Thanks, Ruud
Hi Ruud,
When your Growatt inverter doesn’t have modbus onboard, it’s possible to make it work by adding a modbus interface. Here’s how Danee did it:
Thank you Peter for pointing me to this description of a working solution that I may end up with inplementing as wel.
Does this mean that wireless solution (via the dongle) is not possible at all?
Yes, connecting to the inverter over wifi isn’t possible, you’ll have to take the modbus route.
Thanks for confirming
