Sandy
April 7, 2025, 2:27pm
1
Does somebody knows that the solar inverter Growatt NEO 800M-X & the battery NOAH 2000 works with Homey Pro?
I was thinking of buying this set…
Greetings
Sandy
You probably get a useful response by asking in this topic:
Purpose
The difference of this app and the already existing solar panels app is that this app reads the data directly from the inverter.
The solaredge api and others are mostly limited to 300 calls/ day, so you get only updates every 10-15 minutes.
The modbus app receives data every few seconds.
If you have the Solaredge energy monitor installed you can maximize your self-consumption and limit your exported power by using it. You can make flows based on your generated solar power, exported p…
It is intended to be supported through cloud with the new official Growatt app.
This app is the official Athom app for Growatt (WORK IN PROGRESS)
It works with the Growatt cloud, so no local connection.
At the moment only Solar Inverters are supported. Additional drivers will be added.
To be able to add new drivers, e.g. for home storage batteryies I need volunteers who are willing to share their Growatt account login. Please drop me a DM if you are willing to do this.
Also please test the Solar Inverter driver and give me feedback in this thread!
