I’m currently in discussion with Athom support, but if they aint gonna fix this (I want my phone charger back for its original purpose) I’ll have to return it under warranty as this is unacceptable.
I think its a coinsidence that changing power supply gives less reboots. The restart did not stop with me despite 65W laptop charger. Beside i see the red led indicating that homey has crashed. Considering i factory resetted 4 times already and switched power supply multiple times i get the feeling that the reboot cant be user error or due to device usage. It just bothers me that every problem reported is replied with “try resseting or change powerbricks”.
This way the problem does not get the propper atention or a reasable timeline for fix
They are gonna send me a 2nd homey to try with the power supplies and with my local backup. So far I cannot complain too much about the aftersales, however, it is troublesome how much manual labour this has become.
I found a tweak that works. Now Homey has been working four days in a row with no unwanted restarts and no errors. I found a better charger with a high amount of watt and I schedule a restart of the Homey every night.
Please do not consider this tweak as a solution.
Is it a warranty issue or will there be an update to solve this? I cannot see how issues with a too small charger will be solved by any software update… Sending a new same sized charger will not make a difference, as seen elsewhere in this thread.
Please advise what to do, so I can get my bigger charger back.
UPDATE: Apps were updated and Homey sent me a replacement charger. Ever since the Homey Pro has been the most stable smart home device I have ever laid my hands on. I am thrilled!!! Shout out to the professional but still personal support at Homey!
I have the same problem, offline every 2 hours. Purchased December 2025.
I’m still trying to figure it out over here and I’m trying to verify a theory. I think these adaptors are pretty sensitive to voltage dips. Currently trying on an entirely different breaker group to find out if this stops it. (much less devices on it). Even though Insights is a bit slow, I’ve now setup my homey behind a Ikea Inspelning plug and I let Homey note when the voltages picks up a new low (215/213/211/209V).
So far I got 1 reboot with a positive hit on 213V (which actually isn’t shockingly low, less then 10% drop). However, if it happens just for a 10th of a second that it actually drops lower, Homey might not register it.
So still a working theory at this point.
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. Please translate your post into English, otherwise it will be deleted in three days to keep the thread in just one language as stated in the forum rules Welcome to the forum!
Please do also check out the categories in other languages:
If you need help, because depending on the trust level of your account, you may have limited permissions, please PM me or another moderator or reply to this post.
Today my power supply stopped working, it’s dead. I took a universal USB, we’ll see if it works better.
To follow up, no its not the power supply with voltages drops that trigger it. So far I am a little unsure, however, the location of the Homey seems to influence the situations. Running it on a different breaker group, the reboots still occurs on that locations (running with an extension cable from another wall outlet). Relocating the Homey without unplugging it and placing it in another room does stop rebooting (temperature of the reboot location is only 2 degrees Celsius warmer, at 22c, well within operation temps). So whatever was interfering with the Homey (although there isn’t a single wireless device nearby) is not interfering with it in another room.
I’m going to close my investigation as the reboots no longer appear on this new location.
I have the same issue with Homey 2023 randomly rebooting after the v12.10.0 update (updated somewhere in December 2025). I also noticed that all my Insight data—temperature, humidity, etc.—is gone. Whenever I try to check the insight history for one device, like temperature, Homey always shows “Timeout 10000” and then reboots with a red flashing light. Are you experiencing the same problem? I have a case open with Homey support, but they keep advising me to reset Homey using USB and recover it. I even bought a new Homey 2023 and restored my current backup, but the issue persists. So, I don’t believe it’s a hardware problem—it’s likely the latest software update. What do you guys think?
I don’t know if this is related or not but I have since dec/jan seen random reboots from an otherwise stable Home Pro 2023. When I looked today the Home Development said:
| rebootReason | “unexpected”’ |
Not sure if it is, mine was doing it straight from the box.
You could look into interference, something thats could be blocking or reacting on the signals.(checked the power supply? Searched for RAM or CPU peaks? Have you start using new apps, devices or flows from that point?)
Since my 2023 has been rebooting up to 15 times/day, I did a factory reset. Unfortunately, it didn’t get any better, now it’s offline all the time.
I have not had a restart in a while. Turns out there was a sensor causing problem.
Because we cant see diagnostic report there is no way to see sensor that is causing this problem. So create a diagnotstic report and send it to homey see where the problem is in your setup.
In my case it was a humidity sensor. So I Removed that sensor and all its trigger cards.
I Also had a couple of cards that made a trend calculation every second. I spaced that calculation out as well to avoid bottlenecking any hardware. I re-added the sensor and im now trying to see after 3 days if it remains stable as before.
I hope this is helpfull to you guys aswell.
I moved mine to another room yesterday. Now it hasn’t lost contact in a day. I hope it work now. I think there was something disturbing in the other room, TV, computer or phone charger???
Who’s to say. I hope it works.
However, it’s troubling if the Homey is THIS sensitive to interference, whether its objects or electrical devices in the nearby surroundings. That signals would be disturbed sounds like a fair possibility, but a device crash feels odd.
@Persan @Boostdb @stefan_kihlberg
If you have the similar observation, I believe it’s SW based , in my case :
- attempted restore to HP2026, random reboot occurred within 12 hours
- attempted to move from CM4 with 4GB RAM to CM4 with 8GB RAM - random reboots still there
- no undervoltage
- no insufficient RAM issues
- replaced even the Ethernet adapter - no effect
- actively cooled - so it’s not temperature issue
After reading some threads about network issues, I tested connecting my Homey outside of my firewall, directly to the internet without any NAT (I know I shouldn’t do this regularly, but it was for testing purposes). Surprisingly, it worked better without any timeouts. Homey was able to read all my insights, temperature and humidity sensors without problems. Did it for a shortwhile, but enough to test insights data was readable without reboots.
Then, I set up a completely new stock OPNsense firewall and placed my Homey behind it without any connected devices Hue bridge, Shelly etc, but the timeouts returned. This makes me think something in my firewall is blocking what Homey needs or Homey changed their software causing required services to be unreachable, resulting in reboots and timeouts. Anyone, tested to connect Homey outside the firewall and can confirm the same?
Note: I have already tried adding a port forwarding rule for port 4459 on both the firewall and Homey, but it didn’t help.
I have a pfSense+ firewall and for me the Homey still works fine (including Insights). To check for any issues with the network requests, you can use the DevTools in your browser. Do you see any failed requests there in the “Network“ tab?
After many weeks of investigating my issue, I finally got it resolved!
My problem started in December 2025. I spent weeks trying to find the cause. Every time I accessed Insight data, it didn’t work and caused Homey to reboot with a red ring. Sometimes Homey randomly reboots. I tried changing the power supply, USB cable, Ethernet cable, switch, access point and even new routers (Pfsense/Opnsense). I opened port forwarding, tried new VLAN, and tried many software and hardware fixes. I even bought a brand new Homey Pro from the store.
Finally, after many emails with Homey support, they told me to turn on experimental updates because they released a new version (RC) that might fix my issue. It did! However, now I’m unsure if it’s a good idea to let Homey control my whole house, especially since software updates can easily break everything outside my control.
My two cents: for those reading this, I highly recommend scheduling time occasionally to turn off your Homey Pro, connect it to your laptop via USB and take a backup. If an update causes problems, you’ll always have a full backup to restore from.
