What to do?
No idea waht you mean. It is available is the store. Is installing and working here.
Also there is a topic specific for questions about the app here: [APP] Aqara & Xiaomi Smart Home - A different kind of Smart Home solution (Zigbee App)
But if you are not clear in the issues you see you probably first need to be more specific
use this (?)
or
I have had the Aqara app installed and Aqara gadgets attached and working.
Now nothing works and Homey shows ”App unavailable”.
The app seems installed. I restarted Homey, try to install it again from the webpage for apps.
The only thing I haven’t tried is to uninstall the app and reinstall it.
I guess I have to connect all gadgets manually again if I do that.
That’s the worst thing to do, if the app crashes contact the developer or Athom.
First investigate the real problem.
As quick fix:
- restart the app.
- over-install from the apps store (without uninstalling first! uninstall would remove all your devices)
Had done that, but tried it again. First the app disappeared. When I restarted Homey it was there and working.
