Hi everyone,
I added a knx button as a switch and created a flow that listens to the “on” status. If it get pressed the status changes to on and then the Garage opens. Afters 1sec I set it to off again.
Now I have a problem with this flow, because the Garage opens everytime the Homey Pro restarts.
How can I avoid this? Or is there a way to correctly add a knx button and avoid adding it as a switch?
Thanks
I know it has to restart after f.i. a firmware update, but you make it sound you restart it on a regular base? That shouldn’t be necessary…
Not a solution, but you can turn off firmware updates, and install them yourself when you think you need it. And you can close the garagedoor right after that
Firmware updates are announced in the Timeline
No I was just wondering why the garage door opened at the middle of the night and found out that we lost power and the homey restarted. But when I am not at home it should not trigger the flow. I need a “cleaner” solution for this
Maybe you can try the “OFF” status?
I changed some settings in KNX so that the status get to be set to off right away. This way it also works if homey need to restart.
