Hello everyone,
I am having an issue with my Homey Pro Mini where my Time and Date-based flows are not running according to the schedule I set.
The flows themselves do run, but they do not execute at the correct scheduled time. For example, when I create an Advanced Flow that should run at a specific time, it may trigger immediately or later than expected or at a different time or than the one configured.
I live in the United States and have already checked my Homey location and timezone settings to make sure they are correct. Other triggers, such as motion sensors, door sensors, and device states, are working normally. The issue only seems to affect scheduled Time and Date triggers.
Things I have already tried:
Restarting my Homey Pro Mini
Checking timezone and location settings
Recreating the flows
Testing with different scheduled times
Has anyone experienced this issue before with the Homey Pro Mini? Could this be related to time synchronization, timezone settings, or a scheduler issue?
Any advice or troubleshooting steps would be greatly appreciated.
Thank you!
Sometimes Homey’s clock isn’t set as should;
You can reset Homey’s clock by moving the map to another timezone, tap somewhere to pin the pointer, wait for a minute, and then move it back to your location and tap on your location to pin the pointer to your place again.
This probably solves your issue.
Thanks for the suggestion. I actually tried that already. I moved the map to a different timezone, waited, moved it back to my location, and pinned it again. I also restarted my Homey Pro Mini afterward.
Unfortunately, it didn’t fix the issue.
The problem isn’t limited to scheduled times. Homey can’t even correctly distinguish between daytime and nighttime. Flows that depend on the Day/Night condition don’t trigger correctly either.
I also verified that Settings → General shows my timezone correctly as America/Chicago, so the timezone configuration appears to be correct.
At this point, I’ve tried all the recommended troubleshooting steps, but time-based and day/night-based flows still don’t work as expected. It feels like Homey isn’t processing time correctly, even though all the settings look right.
Has anyone else experienced this with a Homey Pro Mini, or could this be a firmware-related issue?
