Vanochtend weer offline.
Maar een ticket ingeschoten en binnen 20 minuten (!!!) een reactie van Athom. Supersnel!
Hun reactie staat hieronder.
Ik ga maar eens aan de slag en laat later weten of ik iets ontdekt heb.
Hi Bernd,
Thank you for reaching out to our support and I’m sorry to hear you’re experiencing connectivity issues with Homey Pro at the moment.
In some cases we’ve noticed that a faulty power adapter or USB-C cable can cause some instability in the WiFi connection. Please test your Homey Pro with a different adapter. Make sure it has 5.2V and at least 2A (2000mA) output. If this does not resolve the issue please test using a different USB-C cable.
If this resolve your issue please send us your address details so we can send you a replacement power adapter and/or USB-C cable. If you still find the connection to be unstable please try out the tips listed below:
If you are experiencing WiFi instability while you currently have a mesh WiFi network please try the following options:
- Make sure that Homey Pro connects to one dedicated acces point at all times without the ability to switch between acces points.
- Give Homey Pro a static IP-address.
- Try to split your 2.4 GHz and 5 GHz into separate SSID’s to prevent any switching between the protocols. If you can’t seperate the bands please disable all Band steering options to prevent switching between the bands.
- Connect Homey Pro to a dedicated 5GHz band. Since BLE and the 2.4GHz Wifi are on the same frequency they may interfere with each-other.
- Connect Homey Pro to your network using the ethernet adapter only to prevent any Wifi issues from cropping up.
If you are experiencing WiFi issue while not having a mesh WiFi network, please try the following options:
- Give the Homey Pro a static IP-address.
- Connect Homey Pro to your network using the ethernet adapter only to prevent any WiFi issues from cropping up.
If none of the above tips resolve your issue. Please try to create the following set-up to test wether it might be a network setting or Homey Pro issue:
- Set up a Wifi router with a dedicated SSID on either 2.4GHz or 5GHZ. Use no special character in either the SSID or the password.
- Connect Homey Pro to this network.
- Check the stability of this set-up
If you find that Homey Pro is still having some trouble with keeping up the connection, please try and create a basic mobile hot-spot on a mobile device to see if Homey Pro is stable when connecting to that.
If, even after all these tests, Homey Pro is still not connected properly. Please send me a new diagnostic report right after such an instability event has happened. To do so, please open the Homey mobile app and go to More … → Settings → General and select “Create Diagnostics Report”. You’ll get a unique ID, which I need to view some diagnostics. Please copy this ID in your reply to this e-mail.
If Homey Pro is able to make a stable connection to any of the above set-ups there is some setting in your main network that might be causing the instability, please look into the network settings by referring to the manual of your router.
Can you please let me know if this solves your connectivity issue?
