Homey Pro and Bridge
If I use a Pro, plus a Bridge in another building (satellite), with the same WiFi network, and are using 344 MHz products - I can read in many places that the satellite can extend the coverage and receive 344 signals. But what about transmit? Can I set up one flow that will cover 344 products in both the main house (Pro) and the other building (Bridge)?
I hope you mean 433 MHz ? That is what Homey Pro and the Homey Bridge support.
Using Satellite Mode
Homey Bridge can also act as a transmitter for your Infrared and 433 MHz devices. You can use Homey Pro or one of your Homey Bridges as an antenna per device.
For example, if you have a TV in the bedroom, place Homey Bridge near it. Homey Bridge will transmit Infrared signals to the TV instead of Homey Pro in your living room.
Follow the steps below to set this up.
For each device you can choose where to Transmit the signal
For the Bridge you can set if you want to use it ALSO for receiving (can sometimes result in duplicate triggers)
Hi, yes sorry -433 devices.
Thank you for the reply
I have Telldus today, but consider changing to Homey.
Den mån 17 feb. 2025 19:48Geurt Dijker via Homey Community Forum <notifications@athom.discoursemail.com> skrev:
