Hello!
I am planning to replace the existing other brand Z-wave smart home system due to operational problems. However, I have not used the Homey system before, so I would like to ask for help with a few questions.
It is a larger 3-story family house, where there are nearly 90 of 230V smart devices (Fibaro, Heatit, Heltun, Aeotec) and 30 of battery Z-wave devices.
In the past, signal strength and communication problems caused by this arose, as the area is large and the walls are thick in the basement, so the devices were often disconnected from the Z-wave network or operated with a very long delay.
For the above reasons, I am thinking about building more of the Pro + 2 Bridge Satellite mode described on the website, but I do not fully understand how it works.
In satellite mode, does the Bridge device act as a repeater/range extender for the Pro center? Does it communicate with the central point locally via Z-wave or LAN/WIFI or does it work on a Cloud basis? If it is based on the Cloud, it will unfortunately not be a suitable choice, because in the event of an internet outage, the system will not be fully functional. In such a case, what would be the right choice to cover the entire Z-wave network of a large and multi-storey building? Should several control centers be linked together?
Thank you in advance for your respectful reply!
Best regards, David
