good evening, since this afternoon my device has no longer been able to connect to the internet. I’ve tried them all, even resetting and deleting the device and then adding it back…but I can’t…in the procedure it tells me to connect to homey wifi but there isn’t … .any suggestions on what I can do? thanks
For support or issue resolution, first have a look at support.athom.com. If you are unable to find the answer to your question on support.athom.com you can send a support request to Athom via https://support.athom.com/hc/requests/new.
If you need help you can read more about how to submit a support request.
When filing a support request, make sure you add all necessary information so Athom can help you as quickly as possible.
This might help
Was the adapter.
Thank you all ![]()
