Hi all,
Bit of a problem I’m currently stuck on so was hoping someone smarter could give me some pointers on how to resolve this.
I’ve got 2 different locations one with the homey and a bunch of other stuff that works just fine and now recently there’s a new location where I’ve got some solar panels connected with a P1 meter from Homewizard.
The 2 locations both have a Watchguard firewall with a tunnel set up between them, so there are 2 networks 192.168.16.0/24 and 192.168.15.0/24 I can access all devices from one on the other, so if I’m in the 192.168.16.0/24 network and surf to say, the printer webpage in the other network (192.168.15.48) it opens just fine, tunnel connects fine with no errors etc… so far so good.
Now what I’d like to do is add that p1 meter that’s connected to the wifi of the 192.168.15.0/24-network to the homey app, but homey is incapable of finding the P1 meter (it did find the other P1 meter present in the 192.168.16.0/24 network).
If I had to make an educated guess I think homey is merely scanning the local network (so the 16 range) and ignores the 15-range, afaik this wouldn’t be a problem if I could manually tell homey where to look but since I can only have it scan (and not find anything) I’m somewhat stuck.
alternatively I figured I might move the homey to the other network, pair it with the P1 meter, then move it back again but since it only connects with Wifi I’d have to reset it, connect it to the other wifi network, pair, then move it back and change Wifi again, though I’m not too familiar with this process (will it delete my config?) and I’m unsure it’d even work like that.
So that’s my current situation, any help would be greatly appreciated.
